Air Compressed Filtration/Regulation/Drying
mobius1982
Ottawa Ontario Canada
I have just purchased my rapidair maxline 3/4 kit and plan to run a pull down reel on the ceiling and 4 different jacks on the wall.
I am going to purchase an 60gallon 2 stage air compressor with approx 15cfm.
Can someone recommend a Filter/Regulator/Dessicant Dryer kit (but no lubricator) since I will be spraying and doing woodworking related tasks with the system.
I am looking for low $ high quality. I plan to only put one system as close to the compressor as possible and have all my jacks the same air pressure. Also wall mountable would be ideal or brackets to help wall mount the system
Any feedback and ideas would be super helpful.
Thanks
mobius1982
I would like to get a 5 stage setup without a lubricator. I will attach one down the line on air ports not used for spraying.
Does anyone know where to buy a 5 stage kit for a 60 to 80 gallon air compressor that does not cost a fortune.
Here is what constitues a 5 stage kit on most sites I have seen
five stage filtration includes: 1) 40 micron filter with 9oz metal bowl with sight glass. 2) .01 micron coalescing filter with 9oz metal bowl with sight glass and pop-up indicator. 3) one gallon desiccant dryer that lowers the dew point to -30 deg. F. 4) 3 micron filter with 9oz metal bowl with sight glass to protect from desiccant dusting. 5) 5-125psi regulator with three position adjusting knob. The unit includes gauge, shut off valve and one gallon of desiccant.
Thanks
