driftpin
- Location
- Miami FL
- Price
- $225
Campbell Hausfeld air compressor 240 volt 30 gallon, portable, on wheels. This is rated at 8 SCFM @ 90 PSI and will do anything you need. New electric switch and unloader valve, new head gasket, oil changed regularly. This is NOT a noisy, aluminum direct-drive compressor! It has a cast-iron two-piston ribbed belt drive compressor, and a 15 amp 240 volt electric motor. I have owned it many years and bought it from the original owner and bought a bigger stationary unit. It has a ribbed, belt-drive Century electric 240 volt 15 amp motor, and a quick-disconnect hose fitting. This compressor will probably outlast you.
