So, I'm setting up my 60 gallon Craftsman Professional compressor. I am trying to make the driest air I can as I'm trying to get into paint. I saw a nice writeup on this forum which referenced a guy on YouTube called Chevahaulic. He demonstrates a setup using an old car A/C condenser coming straight off the compressor head, leading to a tank, going to the main compressor tank. Now, I plan on having other driers in my setup, post-tank, but my question is in regards to my condensation tank.
If I run compressor > condenser > Tee fitting connecting both a (drain tank collecting water via gravity) and (60 gallon air tank) obviously everything would be at operating pressure, which for my tank is 150 psi. I bought a Harbor Freight 5 gallon portable tank to put in place for my water catch can. I would drain it every other day or something, but my problem is its "technically" rated for 125 psi.
I want to throw out here, I am an engineer, and having gone to school, I know things are rated for a decent bit more than they can physically hold. Would it be unwise to hook this under-rated tank to my system knowing it is going to hold more pressure than it is rated for? Surely a welded tank can hold up to snuff... My main reservation might be if, over time, it rusts, since it is a drain tank, it might be a problem? But even then...
Any help people can provide is appreciated.
