Hey.
I've been reading tons of stuff online about air drying since I was planning on buying a compressor. Finally ordered a NorthStar 47500. Thanks to a lot of good threads on here, I've got a pretty good grasp on the system I'd like to build with an aftercooler between pump and tank, and plumbing after the tank.
Even after reading through some threads, I'm having trouble finding the right part to use as a drain between the aftercooler and tank. I would like something with an automatic drain. Can you guys please point me in the right direction on this? Something under $100 would be great.
Would an "air filter" such as this work? Is that different than a "water trap" or "water separator"? Would the semi-auto drain drain the bowl every time the tank is filled?
