sweetk30
helping a friend fix his kobalt compressor . when it shuts off its leaking air from the unloaded hose at the pressure switch . pressure switch is new and still does the same . he figured the pressure regulator he had on the out let was bad and got a new one still same thing no leaks until compressor shuts off .
is my thinking correct the tank inlet check valve has gone bad ?
