sti491
Hi all. I have a Quincy QT5 80 gal vertical compressor. Bought it new 2 years ago. Just got around to plumbing the bottom drain so its easier (less messy) to do, and it's way quieter doing it.
The manual says to purge air from the the tank down to 35psi before opening the drain ball valve to let the water/moisture out. With it plumbed now, it's easy and quiet enough to just open the drain with my foot for a few seconds. Even at full pressure it is no longer ear splitting loud, as was when the drain end was open at the valve.
So my question is, is it really necessary to purge the air out of the tank down to 35psi before draining it? It's a big tank and that takes a while. It seems to get the water out just fine doing it a full PSI?
