Hi I have a 4 year old air compressor I originally got from harbor freight, and they no longer supply the gasket, but the original gasket failed.
I tried to make one about a half year ago with ultra black RTV silicone gasket maker and after a few months it leaked. I wanted to redo the seal to fix the leak and I can not get it removed. I used a rubber mallet and tapped on all the sides and put a thick screwdriver through the oil plug hole and tried to pry it that way, and it cracked a bit of the metal on the inside (see pic). I dont think it is important, I think its just to hold the plug in place, but can not be sure till I find out how to open it up.
Another option that came to mind is heat, but I dont want it to go up in flames because it is covered in oil due to the leak.
Any ideas?
in the photos below the first one shows the compressor and the gasket cover is marked in red slashes. The other picture shows the area that got cracked as I was trying to pry it off.
Any ideas?
