Air Compressor Drain issue.
Junkman
Northeastern CT
Today, as usual, I drained my compressor tank by opening the ball valve after using the compressor, until all moisture came out. I noticed that even though the valve was open, that the air had stopped. I checked the tank pressure, and it was 100 PSI. I then drained the air from the tank, by leaving one end of a hose open, until it read "0" on the gauge. Removed the ball valve, and checked for any obstruction, but there was none. My only thought is that the rush of air leaving the tank, cause an ice formation in the ball valve. What are your thoughts on this?
bas157
Near Philly
Mine does this quite often. Couldn't figure out why. Is there any good way to prevent it?
930dreamer
Amarillo,TX and Stinnett,TX
You poked about inside the tank with a drain valve removed? This happened to me, I drained through the hose, removed drain valve, poked a wire into the tank while I started the compressor again. Enough **** plugged the tank and finely broke loose.
J
Junkman
Northeastern CT
I poked around with a piece of wire, and there is some **** in the bottom of the tank, but I am not sure how I would get it out. I am thinking that this summer, I will remove the large steel plug at the end of the tank, and see if I can put some type of cleaner in there, and flush it out.
gungatim
west mich
mine does that all the time. just leave it open. eventually the ice will melt a bit and shoot out. happens 3 or 4 times over the course of draining it.
something to do with the rapid expansion of the air as it leaves having a cooling effect, same reason the compressed air condenses in the tank and thus the need for a water separator or franzinator.
gdocktor3
Connecticut
That plug is in there and will only come out with heat. My 3/4" breaker bar fit mine perfectly, but even after heat I had to really hang on it. It also proved a bit difficult to completely seal when reinstalling it. I used teflon and eventually had to add some pipe dope. The hardest part is cranking it back in without the damn thing tipping over.
Danglerb
SoCal
PV=nrT, P is absolute , V is volume (which doesn't change in this case), n and r are constants, and T is temperature, again absolute as in Kelvin. So its cold at the exit valve.
BTW just one of my pet topics, but all the water never drains out.
