Air Compressor Drain
dawgn86
Home
Good afternoon,
I have an older Craftsman 33 Gallon horizontal air compressor that is about 18 years old. Model # is 919.165330.
It is hooked up in my garage and I am looking for the best way to drain the water from the tank about every month or so. It is only used for general uses around the house, etc.
Anyone have suggestions for a setup that would make it easier?
Thanks
FMB4
You should drain it after every use. That said, their are any number 'quick' drain valves that you only need to pull a cable to drain. They also make 'self draining' valves in which you need not do anything (but to contain the water drain-off if you prefer).
FredWanaker
NorCal
I have an elbow screwed into where the petcock was. That elbow goes to a steel pipe that angles out to the side of the compressor. There is a small ball valve screwed onto that. Then I have another elbow and a barb. I take a hose from the barb to outside the shed. At the end of the day I crack open the ball valve and drain it. All the moisture and oil in the tank blows out the hose.
ScaldedDog
Sedalia, CO/NSB, FL
I just have an auto drain on mine. I didn't need it to drain every 45 minutes (the max interval on the one I have), so I plugged it into a wifi-controlled outlet, and set it to energize for a minute every morning. The net of all that is the compressor gets a 2 second drain every day.
Every month is nowhere near often enough.
Mark
rayra
Escaped from Los Angeles
90deg throw ball valve is the way to go, to hell with the petcocks usually installed.
that said I just have the petcock sightly cracked open. I don't use mine frequently and when I do rarely more than an hour or two. And I never leave things pressurized. So I just let it bleed down, which also spits out the small amount of water. It's Vegas, 15% humidity most of the time. Except when it sprinkles just enough to make our cars look even dirtier.
nadogail
Coronado, CA
Took out the pet **** and installed a street ell, came out of the street ell with a ******, connected a ball valve that i can operate with my toe.
rwreuter
Mulvane, Kansas
Screw a ****** into the bottom and place a ball valve in it....drain periodically.......NO NEED TO DO IT EVERY TIME YOU USE IT.
Sumboodie
AK
Mark
Depends on location and usage.
I drain mine maybe once or twice a year. It's frozen ~6 months a year though. I don't get much out of it.
mike93lx
Richmond, VA
On my portable, I drain it when I hear water sloshing around in the tank.
But it's aluminum
On my last large comp, I did what many here have suggested and added an elbow and a ball valve to replace the stabdard petcock.
jeep63
Maryland, USA
This thread is timely for me. I just moved and my compressor has not yet been anchored and hooked up. I will add a more convenient drain now. When we moved I cracked the petcock and it drained oily water for quite a while slowly and over a few days; it just dripped out over time since there was no pressure.
I hope to be better about draining it in the new garage with an easier setup to drain...
65ranchero
Danville, VT left NJ forever
^^^^^^^That's what I do.
My tank is vertical and the original twist open drain was a pain to open and had to get on my knees to open it.
I also will open the drain from time to time If its not been used for a while , sometimes I get a little moisture sometimes not.
kbs2244
hook a broom stick handle to the ball valve and route the output hose through a hole in the wall to make it so easy to do that you have no excuse not to it
D
dawgn86
Home
Thanks for all the replies!..I will figure out something.
I also read where you can attach a small muffler to quiet these down while running. Has anyone done this?
mike93lx
Richmond, VA
Lots of info here on intake silencers. Searching will definitely yield you something to work with
Citation
Indy
Looking at that model,
it might take a bit more to create an intake muffler system. A number of compressors have a simple threaded connector where the muffler/air filter housing attaches. You might have to fab up something for that model. Do search on YT for air compressor muffler ideas.
My compressor came with this rectangular filter
https://www.fix.com/parts/compresso...ir-filter-assembly-4-quot-diameter-vh901700av
Part was lost in a move so I replaced the whole thing with the updated one here
plus 14" of rubber hose slipped over the intake port. Yes the rubber hose really matters. It's a trick I learned from my California Air Tools compressor.
Something like this minus the PVC part - that compressor is very similar to mine.
D
dawgn86
Home
on the horizontal model, where would the intake silencer screw into? is it 3/8" NPT
