Hello,
I got a new air compressor system.
It's a big three-phase unit.
It has an Ingersoll Rand filter downstream on its pressure line.
This filter has a water drain valve with a ****** at the bottom.
Is it normal for that ****** to leak a small amount of air constantly?
I do not have experience with such a system, so I'm unsure if it is working properly or not.
This link below is the replacement part number:
EDIT: Can't post the link because reasons.
To be able to post links or images your post count must be 5 or greater. You currently have 1 posts.
Please remove links from your message, then you will be able to submit your post.
The part number is
Part #: 88349527
The part number is
Part #: 88349527
