I've got a 2hp/120v 25-30 gallon from Zoro, and it runs mine pretty well. I would've liked to go balls-out with a 240v 2-stage, but I didn't have the room, or the room in my panel to add an outlet... as it is I put 2 existing circuits on a tandem breaker and added a 2nd tandem to provide dedicated circuits to the compressor and the rest of my shed/shop. It's also about the most serious compressor that's easily portable, and it is head and shoulders better than a pancake or hotdog unit if I have to use it at a family member`s place.
I spent a few bucks fixing the airflow by replacing fittings also. Stock was a 3" 1/4NPT ****** to the switch, then the regulator. I used a 3/8 tee, added a valve and coupler at tank pressure, then a valve and coupler off the original regulator. It only hits 130psi, so I've never bothered with the regulated output, it even runs my air chisel competently like that. Not awesome, but nothing to complain about at home. The necessary fittings are probably <$40 from McMaster in forged steel.
