gahrajmahal
Sorry, no "Before" photos! This is my 25+ year old Black Max Sanborn compressor purchased at Sam's Club. It has been a reliable workhorse for me. It received a Harbor Freight hose reel about five years ago and other than a few Mobile 1 synthetic oil changes I have done nothing to it. This year was like many others and I worked it hard running DA sanders, air nailers, air grinders, air drill with nylon wire brush, impact wrenches, tire inflator, blow gun, and multiple body working tools this year along with a new Iwata HTE (high transfer efficiency) Air Gunsta spray gun along with my old stand by Binks and Devillbis guns.
It was the middle of summer when I repaired and repainted my daily driver 2020 Corolla where I made some of the initial compressor upgrades. I added the cooling fan, a take off from our old furnace. I added a drip leg with multiple quick disconnects so I could use a dedicated dessicant drier plus regulator for spraying auto paints. I could then use a new hose for spraying.
It was the fall when I was dyeing our leather club chair and ottoman when the pressure switch contacts welded themselves closed and caused a run on. I could only shut it off by quickly pulling the fuses at the power box. It was then I started to shop for a new pressure switch. After a lot of research and prices from $15 to $hundreds I came across a U.S. company called Condor. Using the motor tag information and compressor information I called the factory to get a recommendation. This will be your best bet for getting the right replacement. I needed 95 psi start, 125 psi stop, (4) port 1/4" NPT 240 volt 30 amps. Model MDR 11 Pressure Relief Valve. Cost? A modest $45 + shipping.
I've always disliked the way the compressor jerks violently to life and wanted to see if I could also add a soft start to the system to allow it to ramp up to speed. This is what I installed from Newark. $75 + shipping.
I found a great see through outlet cover at Menards to cover the Soft Start. I can open the cover and adjust the speed of the soft start. I would say I have it at about 1-2 seconds before full power. Initially it was about 5 seconds, but the motor was really groaning .
Now if I could just figure a way to quiet down the intake and running noise I would really love it even more!
