Hey all,
(admins forgive me is this is in the wrong spot.)
I have a couple of questions about air compressors for a 30x30 garage. I have been reading the reviews and have a better understanding due to the information on here. The most common conclusion is get the biggest you can at the time, and CFMs.
I work on personal autos, have a plasma cutter, grinder, etc. and would like the option for sandblasting cabinet in the future. I have been looking at 60/80 gal tanks in the 5hp area and would of course like to keep it under $800 range. (dreaming -
I have been specifically looking at the two harbor freight compressors after the review from Venom2164. I am thinking one of these would be a good way to go, since they meet my requirements and cost. The only difference I can see is price and one is "factory refurb" the other is not?
http://www.harborfreight.com/5-hp-60-gallon-165-psi-two-stage-air-compressor-55391.html
http://www.harborfreight.com/5-hp-60-gallon-165-psi-two-stage-air-compressor-93274.html
As of last night, I located this Craftsman Pro 80 gal 2stage. 7hp max on CL - Thoughts? I am a little leery on purchasing used. I don't want to get it, then it **** out in 6mo. However, craftsman has usually worked out well for me.
http://dallas.craigslist.org/ftw/tls/5156929860.html
Info I could find based on the model number>
Model No. 919,167802
Max. Developed HP 7
Running HP 5.5
Sore 4.134"
Stroke 2.165"
Voltage-Single Phase 240/60/1
Minimum Branch Circuit Requirement 30 amps
Fuse Type Time Delay
Air Tank Capacity 80
Approx. Cut-In 140
Approx. Cut-out 175
SCFM @ 100 psig 17.4
SCFM @ 175 psig 16.9
As always, thanks for the help!
-Josh
)I have been specifically looking at the two harbor freight compressors after the review from Venom2164. I am thinking one of these would be a good way to go, since they meet my requirements and cost. The only difference I can see is price and one is "factory refurb" the other is not?
Max. Developed HP 7
Running HP 5.5
Sore 4.134"
Stroke 2.165"
Approx. Cut-In 140
Approx. Cut-out 175
-Josh
