I bought a 2000 model speedaire recently off of cragis list. 80 gallon two stage 7.5 hp, 17.1 cfm at 90 psi for $250.00. I thought I new a little about air compressors. Supposedly the guys grandad died and he was selling all of his tools. The compressor is in good shape it needs a pressure swith which I have ordered. Also I replace the belt. While replacing the belt I noticed it looked like themotor had been changed out. The motor is a dayton but only 1740 rpm and says 2 hp drive. Did i get screwed. Shouldnt the motor also be 7.5 hp or is the pump rated at that. If it is a lower hp what will it do to my output. Seems like it takes a long time to get to 50 psi which is as high as ive had it due to pressure switch. If the motor is a problem what motor should I buy. the Dayton 5 hp I have looked at are like 450.00 which makes my air compressor not such a good deal. Thank you all in advance for your advice.
