adamz
Fellow garage journal members,
I'd like to pick your brains regarding the potential purchase of a used 2002 FS Curtis 5e2ht8-a2 with e-57 pump 80 gallon horizontal or a new Quincy QT-54 60 gallon vertical air compressor. I run mostly automotive air tools, some portable abrasive blasting tools, painting equipment, and I keep pestering my wife into letting me buy a CNC mill or lathe for the shop (dream big, right?!).
Here is my situation:
FS Curtis 5e2ht8-a2
To begin, I could purchase this compressor and get quite a deal. When I went to look at this compressor, I was informed that it had sat outside unused for 6-12 months. We were unable to turn the pump by hand, to which we removed the cylinder cover to discover an amount of build-up/rust that was inhibiting the large piston from completing it's stroke. They were able to remove the rust and clean up the piston/cylinder, and I requested they reassemble it and run the compressor (knowing that two gaskets needed to be replaced) so I could verify the compressor and motor did at least run. Everything fired up without hesitation but would not hold pressure past 55psi, which I figured was attributed to the two gaskets being out. This didn't bother me so much as seeing some rust on the crankshaft when looking into the crankcase. On top of that, a brownish oil came back up from under the oil fill cap... This greatly concerned me.
The seller contacted me today stating that they had fixed up the compressor, replaced the gaskets, and flushed the oil twice and stated that everything was running fine now. They are now offering to deliver the compressor to me and for less than they initially asked as I had a bit of a drive to check this one out.
Would any of you more knowledgeable individuals have any reservations about purchasing this compressor? Are there other outlets for parts short of buying a brand new pump for $1000?
Quincy QT-54
This one is a bit more straight forward. Brand new, $1400 for aircompressorsdirect and $35 lift gate fee. I could easily extend the 1 year warranty to 2/3 years for another $170.
I would greatly appreciate any insight or advice! Thanks!
FS Curtis 5e2ht8-a2
Quincy QT-54
