rantingmadhare
- Joined
- Nov 12, 2016
- Messages
- 10
I acquired this Ingersoll Rand SS3J5.5GH-WB for a bargain but is missing the regulator and has some other monkey business done to it. The Honda GX 160 has spark and a mostly clean gas tank, so will be getting just a tank flush, oil change, new air filter, and new spark plug. I plan to change the oil in the compressor unit and replace the missing air filter unit. It has suction on the inlet, so hopefully it will put out some pressure. I will not run it though without the filter. Any other suggestions for maintenance checks? This is my first compressor, though I have operated this type before.
Also, any suggestions on a replacement regulator assembly? Original individual Ingersoll Rand parts are adding up fast to much more than I bought the unit for. At least this came with an unloader valve and overpressure relief valve, so should be somewhat safe to operate as-is sans any manual pressure adjustment? If I get this operational it will also get a paint job to address the rust.
