W_KY
In my 28' x 32' home garage I have a L shaped set of steps in the back right corner. Under the stairs there is a boxed in closet with 220 already there.I can also get 110 there pretty easy as well.
My question is: I can get a horizontal 30 gal compressor that goes under the landing in the steps or I can get a vertical 60 gal compressor that would sit in the closet portion. The down side of the vertical is that there would only be about a foot to get around it to use the remainder of the closet. The downside of the horizontal in that it has half the capacity and not near the CFM. It also is pretty expensive in terms of dollars and capacity. The horizontal would definitely make better use of some space that is hard to use right now.
My air uses aren't great. I get by with a 3 gallon little sears compressor right now. I mainly run nailers for woodworking with occasional cleanup with blow gun. About the most I could see myself doing is using an impact or maybe a paint gun to paint some cabinets or something.
Here are the horizontal I'm considering:
https://www.amazon.com/dp/B000E27JW6/?tag=atomicindus08-20
Here is the vertical I'd probably get:
http://www.harborfreight.com/5-hp-60-gallon-165-psi-two-stage-air-compressor-93274.html
I realize these are two vastly different machines in terms of output, I'm just not convinced I need the larger compressor taking into account future uses.
If I put the compressor under the landing of the steps I can probably put my dust collection in the rest of the closet once I get around to getting it. One thing I'd need to work on is making sure it doesn't get too hot but I think I can handle that with some vents.
Bigger is better but not always. The IR unit your looking at is small but for what you want it should work. Biggest advantage is it is portable so you can wheel it where you want. Being an IR the quality should last you a life time if taken care of. An 1/2 air impact takes around 4-5 cfm. If yours takes more than that then you just have to wait until the compressor recharges. I have a 3 hp Sansborn unit in my basement wood shop. After there specsmanship, it is really a 1-1/2 hp unit. It does all I ask of it and it was all I had for years. Purchased it around 1990. Worked an impact just fine. Just had to be patient to give it recharge time. Out in the barn I installed a large IR vertical 5 hp unit. That needs to run a sand blaster which uses a lot of air.
