I've been researching used air compressors for a while, probably for months, reading up about different ways to test them.
Only today have I stumbled upon a couple of formulas on how to calculate the actual cfm. Which it seems would be a really important test, yet I don't see it recommended for people buying used compressors.
So I was getting ready to buy a compressor, a medical compressor of all.
It's actually rated 4.5 hp, 15 cfm at 80 psi.
So I went to check the compressor, AirStar AS70.
From an empty tank, the manual says it should take 2min and 40 seconds to fill up.
I timed it, and it took around 4 min and 36 seconds until it turned of.
I then let the air out until the compressor kicked back in, and waited until it stopped again, 50 seconds this time.
So I'm wondering what these results mean. I have no idea what gets worn out on the compressors, but just not sure if it's on its last legs or not. How much life does it have left, or how many hours?
Also, based on the calculations from the manual, the output is around 9-10 cfm, not 15. Because the manual says that the compressor should full in 2 min 40 seconds. And based on that, it doesn't get even close to 15 cfm.
Here's the formula I used
Actual cfm = TANK GALLONS x .536* x PSIG divided by SECONDS
(30x.536x90)/270=5.3
I rounded the numbers. This is based on how long it actually took to fill it up from empty.
