shamrock12
So last year I purchased a portable 20 gallons Campbell Hausfeld #VT640600DI (5.5 SCFM @ 90 PSI) air compressor. Today while doing some work, I noticed that it didn't kick back on and found out that a breaker has tripped. Thought that was odd since I never had that problem before using the same outlet, so I reset the breaker. It tripped again a few seconds later. So after some troubleshooting, I found out that the compressor can start and run when the tank is empty and open. It will continue to run until it reached the set pressure. But when the pressure get below the set point, the compressor struggled to start again and thus trip the breaker. I inspected the check valve and found it to be working properly. So I took out the capacitors and tested them using analog meter and they seems to be ok; however, I do not have a DMM with capacitor setting, so I am not ruling out the capacitors yet.
What I don't understand is if the check valve is working, that the compressor can only start and run successfully when the tank is empty
It did seem to take a tad longer to get it going though. If there is a small amount of air in the tank, like 20 PSI, the compressor would struggle to turn and run, thus drawing too much current and trip the breaker.
Is there anything else common that I should inspect/troubleshoot? The compressor is only a year old and has been used about once a month. Today weather was nice and warm, so the oil viscosity is not an issue at this time.
It did seem to take a tad longer to get it going though. If there is a small amount of air in the tank, like 20 PSI, the compressor would struggle to turn and run, thus drawing too much current and trip the breaker. Is there anything else common that I should inspect/troubleshoot? The compressor is only a year old and has been used about once a month. Today weather was nice and warm, so the oil viscosity is not an issue at this time.
