air compressor location
dsbratton
Rochester, MN
So I am about ready to spray some primer on some car parts. My garage is long & narrow - about 14'x50'... The car I am working on is in the back half. Air compressor is in the front half which is where I would be spraying some parts. I do have a window by the air compressor which I could open. So how far away from the air compressor should you be when priming in a garage? I have seen some people put a fan by the air compressor. Is there a danger of the air compressor igniting the fumes? If I fill it up and turn off, should there be enough air to prime the smaller parts? See photo below for my current setup & location - Thanks for any suggestions!:
930dreamer
Amarillo,TX and Stinnett,TX
Just check the compressor foam filters after you're done. Hard to tell but the water removing setup probably won't remove much moisture being it's on the air compressor.
D
dsbratton
Rochester, MN
I do have a de-humidifier running in the garage and it keeps it at about 50% humidity. My main concern is I won't blow myself up igniting the fumes. I will check into the foam filters though - thanks!
930dreamer
The main issue is the hot air the pump makes. The longer the air can travel and cool the more moisture your filters can remove.:thumbup: I'd at a minimum use a small desiccant filter at the end of the hose, I'm sure your hose has trapped water in it that will ruin your priming work.
