Air compressor manifold
4v4eye
Dayton OH
I am needing to build a manifold for my compressor to remove water. I have been reading here and checking YouTube and see people doing it many different ways. I was wondering what would more effective, plumbing it from the outlet of the tank or removing the pressure line from the compressor head and plumbing it before the air goes into the tank.
Are there benifits to one way vs the other? I plan to just use copper pipe with built in drain valves.
laser3kw
northen IL
Are you looking to remove moisture from the working air stream or remove built up condensate in the bottom of the tank?
How much do you use your compressor? If it is just occasionally, a "system" may be overkill and an expensive project.
If you are looking for peace of mind, plumb moisture traps in line with the outlet and make the bottom tank drain accessible. Then you have protection to your tools and a way to periodically drain the tank.
The Tool Tyrant
Bonita, Ca. (San Diego)
Realize that water in 'vapor' form is hard to remove. The hot compressed air coming directly from the compressor pump contains water vapor and until that vapor cools and condenses its fruitless to try to remove it.
The best scenario is to add an 'aftercooler', which is plumbed into the system between the pump discharge and the receiver (tank) This will cool the discharge air down enough to change the vapor into 'water droplets' which can then make their way to the bottom of the receiver to be then removed by either opening a manual drain valve or installing one of many different style automatic drain devices, in either case, you can plumb the drain outside or into a container if running outside is not feasible.
The automatic condensate drains run the gambit in cost, the timed system are probably the least costly, next would be the units that drain after each compression cycle and the most costly are the 'Zero Loss' systems which utilize a float and when it's reservoir is full, a solenoid opens and the stored condensate is forced out via tank pressure.
I forgot to mention that the relative humidity in your area has the greatest influence on the amount of condensate your compressor produces. If you lived in the deserts of Arizona, it would be minimal compared to high humidity areas like Alabama or the like.
md21722
Mt Juliet, TN
I just have my compressors feed into an auxiliary tank that I already had. Cost me some money in extra valves and pipe fittings.
The folks building the wall of copper running up and down are putting it after the tank.
Others stick a Hayden type after cooler on the belt guard. That goes between the pump and the tank.
