SEGACDX
So I've been working on this compressor off and on for years and one thing that is making me pull my hair out is this, I cannot find anything to replace these mounts with new ones.
These came off an old Devilbiss unit from decades ago, one of them has a crack in it so I want to replace them with the same kind of thing.
I've looked into motor mounts but no luck, nothing will fit both my motor and also mount to the slide rails on the compressor tank.
These seem pretty universal so I don't know why they don't seem to exist
I have looked everywhere online and have no idea, I have found something similar called a Z channel that look close but If anyone know where I can find something like this I would be ecstatic.
I'll give you a bit of background on my unit, it's a 60-70 gallon cast iron tank 200 PSI, a Brook T182 3HP 1 Phase 240V motor with an old curtis two stage, 3 inch bore, 3 inch stroke with a 1 7/8" HP piston, It makes about 9.5-12 CFM at 800 RPM.
It's old but still in working order I have used it for a few years after restoring it from the sad state it was in before.
I have thought about brazing the crack, or welding but I do not have a welder and I am not sure my propane torch can handle brazing that thick of steel.
If anyone can help again I would be so grateful.
