84scrambler
I have a campbell hausfeld 60 gallon compressor I picked up that is having problems with the motor starting. Its a 220 single phase motor with a start and run capacitor. I don't know to much history on the motor as I bought it used with this problem. I currently have it off the compressor and am bench testing it. I am currently testing it with just the two legs of the 120V wired up and no ground. When I plug it in the motor hums very loudly and turns over very slowly. If I let it do this for about 30 seconds the thermal overload switch gets tripped and I have to wait for it to cool down. During this slow turning I can give it a helping hand and twist the shaft and get the motor to spin up and it runs with no problem. This led me to believe the start capacitor is bad so I bought a replacement, installed it and experienced the exact same problem. Could there be any other issues causing my problem or is there some chance I got a broken start capacitor (start capacitor I am using is roughly 160-190 MFD)?
I did try a third start capacitor with a slighty different MFD (I believe it was 150-180MFD) rating from another motor that works and still had the same problem. Thanks for any input.
