Air compressor motor shaft key
Chaznsc
SC
So....... my AC spit out the set screw for the main pulley on the AC pump, ordered a replacement and that fits fine, but I am also missing the key to the shaft and nothing I have in my assortment fits. Its an old Craftsman 106.173842 and the key is not listed as a part on anything I have seen.
James-W
Southeastern Wisconsin
That is strange, I would have thought one of the keys from an assortment of keys would have fit. I have an assortment of keys too, not sure where I bought them from, but there must be at least 100 keys of different sizes in the box. Maybe you could take a key that is slightly larger, put it in a vice, and file it down to the right size.
C
Chaznsc
SC
My assortment doesnt have that many, I think its like 8 different sizes. Most of the assortments I see online are those half moon shapes. I think I need a square key.
Stuart in MN
Minneapolis
My local Ace hardware has a pretty good assortment of keys available, if you have one nearby go there and browse through their selection.
C
Chaznsc
SC
I have one in the next town over, so I may venture over there. I sure miss hardware stores.
rlitman
Long Island
The half moon shape keys are woodruff keys. They come in assortments, because you need the right sized one.
The other type of key is just a piece of key stock. I buy the square key stock in lengths (like all-thread), and cut it to the size required.
matt_i
SE Michigan
Good to measure with dial/digital calipers to determine the width or take the sheave along with you to the store. There are metric and inch sizes and zero slop is tolerable. It should be a "light tap fit" in my opinion.
Cyberbear
California
There are also pulleys with a collet type clamp that tightens around the motor shaft besides using a key for positioning. These are especially good on older equipment that has suffered damage from pulleys that have come loose and been run until the shaft or keyway has been defaced.
snyder
Baltimore md.
If it uses a taper lock insert on the pulley , it could be a special keystock
Your local bearing, power transfer supply house will have that.
