MATREDGT84
- Joined
- Feb 16, 2016
- Messages
- 4
I have an early 2000's Craftsman 60gal air compressor and the electric motor has quit working. I tried replacing both capacitors but that didn't fix it.
With no belt on the motor the motor will spin up to speed but it takes a minute to get going. If you put the belt on the motor won't spin at all, eventually tripping the overload.
I drained all the air out of the tank and the motor still won't spin the compressor. The compressor does spin by hand. I even tried flipping the motor on and spinning the compressor by hand to see if it would spin up but that didn't work.
The motor on the compressor is a 56 frame which seems common. Except on this compressor they didn't use the 4 bolt mounting plate, but a pin that the motor pivots on. Seems to let the weight of the motor help tension the belt.
So my question is can the guts of a new 56 frame motor be swapped into the old motor case so I can use that pivot mount, or do I need to tell my wife I have to buy my welder now so I can fabricate a new mount for a 4 bolt mount?
Thank you,
Mike
Thank you,
Mike
