No It's an old Sears compressor 1 hp the specs say it can run on a 15 amp circuit by itself. Says at max pressure it pulls 15.5 amps. But I had to replace the pump, and the new one says its a 2 hp. The old motor was working but then it started tripping the breaker like 15 seconds after starting. It has a new run capacitor, but still trips the breaker. So I figure I need to just look for a 2 hp motor to match the new pump.Was the original motor really a true 2hp? I know that some older belt drive compressors really did come with 2hp motors that required a 20A circuit and included a 20A plug (the one with the horizontal prong). I can't think of any one I've seen recently that wasn't a 15A or less motor (my CH included). A compressor rated motor is likely fine, especially if it's $120 vs $350.
Yes the new pump claims to be a 2hp unit, even though the SCFM specs are the same as the original 1hp pump (5.3@90psi & 6.2@40psi)If I understand the new pump is a higher power unit vs the original. Was the pulley ratio changed to account for this?
Are you referring to the breaker for the household wiring or the breaker in the compressor motor (I think all small induction motor compressors have one)
Is the 15 seconds dependent on tank pressure? Does it trip if you leave the tank drain valve open?
It's quite possible the only issue is your motor is too small for the pump. You can probably fix this with a change in pulley size (assuming you can get a smaller motor or larger pump pulley).
If you are looking at $200+ to deal with this can you just get a new compressor? Walmart is unloading some 8 gallon, low flow rate quiet compressors for under $100. Of course that may not be sufficient for your needs.
I used a calculator at blocklayer.comA 2.5 vs 3.5 could make a big difference. That's trying to speed the pump up by 40%. Very big difference and very likely why the breaker would trip.
Definitely try the correct size pulley. Incidentally, how did you decide pulley size? Did you calculate the correct pulley size for the pump's stated operating RPM?
Yeah, I had that backwards. If the correct pulley was 2.5" and you are using 3.5" then yes, it is getting over driven. If you are using a smaller pulley then it shouldn't be getting over driven.No. 2 1/2" drive pulley will turn the pump slower not faster than 3 1/2". But it is true that a 110 circuit will never run a true two horse motor even with no load at all.
