zak77
I have an old Kellogg-American air compressor; about 40-50 gallons and a 1hp motor turning 1725 rpms. The 1hp is a newer motor as the old one was shot when I bought it and I'm limited to 110v for now. It took a while for the compressor to fill up and I thought the head was worn since it was so old so I've been on the lookout for a new head. I happen upon a Campbell Hausfeld vt4723 head for $100 at Tractor Supply so I grabbed it. Now I'm wondering if it was a wise choice or not.
With the stock head in place I figure I'm turning about 560rpm and it takes about 10-15 minutes to fill the tank to 150psi. The 4723 heads only has a max psi of 135psi and if I used the current pulley sizes it'd be turning at 690 rpm. So should I put the new head on or keep the old head on there but change gearing to increase rpms? What would be the best rpm to run this at since I've read anywhere from 600-800rpms.
The odd part is I can not find any info on the current head which has a label on it stating it's model E-210. I'd prefer to rebuild the old head but no parts can be found and I know if I disassemble it i'll tear some gaskets or damage other parts and have no way to replace them. Then I'm stuck with a useless head.
