A friend gave me a Central Pneumatic 100psi 1/3 hp 3 gallon compressor. I want to use it for airing up bike tires etc. I turn it on, it runs but the needle does move. I let it run for a few minutes, pull the blow out vale and very little air comes out. I unhooked the hose coming from the motor going to the tank and it blows air. There is a round ball with a spring that sits inside where you screw the hose into the tank. It doesn't seem to be stuck. Is there any place else I should be checking? There was a little water in the tank, and who knows the last time he used it. Thanks.
