hawkerxj
Just setting up a used compressor (seller said, works good, but motor burned
up)and figured I'd at least change the oil before I try to run it for the first time.
So what is the standard oil/water ratio you guys use(see attached image). Also, is 1/2" of white sludge in the bottom enough?
