air compressor paint?
metalmagpie
Seattle
I have monkeyed with air compressors a little but had never tried rebuilding one until recently. I'm midway through that, but I have a sort of general question. For air pumps with aluminum cylinder bodies, why are they painted at all? I know they get hot, and the fins are to help radiate heat. Same thing on a motorcycle engine and those jugs are usually bare.
And if you are going to paint them, do you have to use "engine paint" or hi-heat paint?
I got a quart of actual Champion paint but I don't have a spraygun setup so I'm contemplating just not painting the cylinders and intercoolers. I'm planning to leave the copper aftercooler lines bare too, for that matter.
metalmagpie
niget2002
Josephine, TX
My cylinder on my pump is not painted.
If I were to try to paint it, I would use a high-temp paint. My pump also has oil in it, so I'd probably look for an engine paint that can hold up to oil getting on it.
rustyzman
Chicagoland
I would recommend a simple Hi-Temp satin or flat black paint for the radiant quality. It will help stave off a little oxidation from ambient moisture as well. How well it will hold up in the long run? Not sure.
