Air compressor parts....
greenbikemike
Twin Cities,Minnesota
picked up a 60 gal and this came with it...was told its for water and oil....sooooo
hows it work and how and where do you put it....it looks like it would be clear then green? I will change out the piping....this will be used for air tools and a blasting cabinet.....
thanks....I did do a search BTW.....
Greenbikemike
joe_padavano
Northern VA
Those are water traps and filter housings (though the filter appears to be missing) that go on the outlet side of the compressor. Frankly, those look like ****. Toss them and buy new ones.
G
greenbikemike
That was fast....thanks...I was told that the green one was for oil maybe,but I couldn't find it on Norgren's Site.....they do look old.....
So should I get two and then have one more at the cabinet,
Thanks again
Greenbikemike
Durka
Howell, MI
Looks like the filter cones are there, but the media is missing. It may have dissolved over time.
Fixnair
Sapulpa OK
Those are complete. The filter elements are there. They are the smallish diameter yellow cylinder just above the white deflector. Unscrew the white deflector & remove the filter element and clean it. Do not use chlorinated solvents to clean these parts. It will destroy the plastic bowl. Use some dawn dish detergent and warm water.
Not a very good filter, these are designed to knock out liquid water and that's about it.
Bob C
^^^ Exactly! ^^^
