edl
Hi All - will start to plumb my compressor (7.5hp(max)/80 gallon; 5hp steady - 26cfm at 90psi; 175psi max - 3/4" outlet from compressor) - and was set to use copper tubing (schedule L 1" with .5" drops) - i would think no issues there - was talking to the person that will be helping and he mentioned black pipe - based on following the threads here, i immediately said "NO" - they can rust and flake inside - as i have read here many times - but he metioned that while this is true for "regular" galvanized black pipe, this was not true for something he called "black orange" pipe - he indicates this is used in natural gas applications in the house and is not prone to inside rusting and flaking - i have never heard of this - does it exist? - is there a more common name? - is it impervious to rust and flaking the way copper is? - is there a certain grade I would get? - should i still use 1" ID tubing? - obviously, the reason for all the questions is that he indicates that the price for this "black orange" pipe is much cheaper than coper and that threading and screwing is much less labor than brazing all of the copper - THOUGHTS? THANKS!!
