HomeTheaterMan
- Joined
- Apr 3, 2016
- Messages
- 493
So, I'm considering this air compressor.
https://www.lowes.com/pd/Kobalt-80-Gallon-Electric-Vertical-Air-Compressor/1000528985
It says its a 240v (reviews say 230v) motor that pulls 22 amps. I know it's meant to be hardwired into a breaker. However, someone asked about using a dryer cord and they did say you could use a plug if the cord/plug was rated for 240v and at least 25 amps. For my situation I feel like having a plug on it would be a much better solution than wiring it directly to a breaker.
Now I have very little knowledge when it comes to electrical stuff in the house. I have this plug for my welder already wired up near where the air compressor will be going. It's on a 40 amp breaker with 8 gauge stranded wire. I have no idea what the name of this style connector is though. Do they make a cord that would be sufficient to safely run this compressor to this plug? Any suggestions on what cord to use?
If I need to wire another style plug in, it's not the end of the world, but it would be easy to just use this one and switch it out when I need to weld.
