Terra Nova
I recently picked up an IR 2131QT impact and it seems a bit, let's say, nutless. It's being run from a Husky 30 gallon 110v compressor. I've not run another impact on this compressor but I really expected more from it. I'm leaning towards insufficient air volume may be the culpret. I'm running a 3/8 air hose with 1/4" harbor freight & Home Depot quick disconnects. I plan to pony up for the Milton V fittings but need to address the other restrictions at the compressor first.
Below is the pressure switch. It's attached via a 1/4" pipe and has a 1/4" outlet. Adding high flow fittings downstream of this probably won't make a big impact. Is it possible to remove the 1/4" pipe shown in the second picture and replace it with with a 3/8" T & tie in there with a shutoff and regulator without confusing the pressure switch? Looks like the switch gets it's signal pressure from the black hose that goes to the pressure line from the pump.
Thanks!
View media item 24715
View media item 24716
Thanks!
