Air compressor pressure control switch
Lkdelta
40 mi.east of syracuse
I think the Air compressor pressure control switch is fried
The pressure control switch is also my on/off switch.
It's "T-eed off" the air tank outlet line
Where would "you" begin to look for a new one, with no idea about the manufacturer?
(older compressor and the name brand sticker is gone)
The compressor patent was issued to Scott & Fetzer in 1977 ...4065237
giving the serial # 01254L 351995 a try...see if I can at least get the manufacturer
Chris.Santamarina
New York
Grainger is a good idea. Go with a Square D pressure swith. The Seimens are junk. Just make sure you buy one that doesn't go higher then 175 psi and has an adjustable differential. Gives you more control over your cut in and cut out pressures.
Chris
Dustball
Hudson, WI
I'd go to my local Fleet Farm and pick up a pressure control switch that matches the existing one the best.
dtt454
missouri
just make sure you get the right one, some have a built in bleed off valve to bleed off head pressure, others dont.
