Craftsman86
http://www.homedepot.com/h_d1/N-5yc...1&keyword=air+compressor+switch&storeId=10051
Is the switch That I bought, And I tried to wire it in to my Sanborn 30 gal compressor, no luck. So I took it to my dads old Campbell Hausfield compressor wired it in the same way as before, and It kicked right over. There is a small micro line hose that runs from the tank to the bottom of the switch into a gator grip fitting. The valve the hose hooks into has a small needle protruding out of the top, and when the compressor is turned off, the switch lowers a plate on the needle draining the air from the tank. Please tell me this is an easy fix, I have 4 hours invested in the install so far and am still not willing to give up.
Now to try and direct wire the Sanborn to make sure the motor is ok, Learn how to use these switches, and order up another one. Both take the same switch.
