I picked up a 230v 5hp 15a 60 gallon air compressor. I think the pressure switch is going since it doesn't seem to kick in at the right kick in pressure. I thought I'd just replace it since there appears to be a ton of cheap switches on the market. Digging a little deeper though, I see there is an amperage issue. These cheapie Lafoo switches seem to be advertised everywhere as taking 26A. Then you look at what the picture of the label says (no one actually posts specs) and it seems that most of them are 12a at 230v. I'm presuming that for my motor, I need 15A @230v or better (and maybe a lot better in a Chinese made part). The switch that is coming off is a Furnas CW-2075-52. I'm looking for a single port switch, 95-125psi, with an unloader.
I'm sure its not as complicated as I'm making it, but I don't want to burn something up. Any suggestions as to which switch is the correct replacement?
