Air Compressor problem,
dennisoates
My two year old Porter Cable 2 hp motor is having a problem. As the compressor reaches max shutoff pressure of 155 lbs it pop the breaker. I see sparks on end of motor near brushes. It runs fine until it gets close to max pressure. I have new capacitors on it. what causes this breaker to pop? I have also tried other outlets.
thanks
Jswain
Calgary, AB
Sounds like it is drawing too many amps at full load. If you have a clamp meter throw it on one of the leads & check/compare with motor for FLA. I would test the capacitors even tho they are new because if one of them is bad it will do this, also check all the wiring & make sure you are getting the proper voltage & have solid connections
Could also remove belt and ensure both pulleys spin freely
  • Like
Reactions: LSU
seber
Deep East Tx.
First determine whether it has brushes or capacitors. I can't imagine how a motor could have both. If it is a capacitor start, capacitor run as I suspect and you are getting sparks in the motor, check that spot. It could be a bad connection or a bad contactor.
The Cobbler
if it has brushes & they are sparking , and blowing the breaker I suspect a bad armature .
I had a small senco compressor for trim that stopped running and it was a bad connection at the termination of the windings inside the motor. a cut off crimp terminal and some shrink wrap fixed it lickity split
D
dennisoates
I did the clamp meter test, and the amp are fine until the pressure guage goes to 145lbs. then the amp skyrocket and the breaker snaps. I checked all wires , i don't have a capacitor tester, would a bad run capacitor cause this?
D
dennisoates
Did you replace the caps because of this? Or did this start after replacing the caps? Why were the caps replaced?
they were replaced because the breaker was snapping? I took the motor to a Electric Motor repair place, so i thought it was fixed.
D
dennisoates
it has two capacitors
Citation
Indy
whateg01
doo dah, kansas, usa
Well, assuming the motor shop tested the motor, it was probably not with a heavy load. If it's an induction motor, there should not be any sparks after it's been running like that. I would suggest maybe taking it back to the shop and letting them know it's still acting up but only under a heavy load.
D
dennisoates
do you think the pressure regulator could be the problem?
Jswain
Calgary, AB
Not unless it was only supposed to be a 125psi compressor and you or someone else turned it up to 155psi. And I'm talking pressure switch not pressure regulator.
If for some reason your gauge was reading low, and someone cranked up the pressure switch setting beyond what the compressor can handle then this could happen
D
dennisoates
There is no setting for pressure
Citation
Indy
Typically you have a pressure switch that is adjustable but not something you would accidentally change. However, if the pressure switch is going bad that could explain a compressor running too high. However, if this is a 155 psi compressor cutting out at 155 psi, well that doesn't seem like an issue.
D
dennisoates
It pops before 155, at 145
SteveH-CO
Southern Colorado
Is this compressor rated to pump up to 155? Is it a 2-stage compressor? I would simply dial back the shutoff pressure to 125-130 and if that keeps it from popping the breaker, run it in that pressure range.
Citation
Indy
If the compressor is tripping/having issues while operating in it's factory range I would not just dial it down and ignore the problem. Something is wrong, fix it before the problem gets bigger.
D
dennisoates
Not adjusable
Stedlin
Duluth, MN
thanks
How can it have brushes if it has capacitors? If it has brushes than it must be DC. If it has caps than it must be AC.
tak1313
Perhaps it's the switch. When the pressure gets to 145, the diaphragm is deforming enough to start pushing against the cut-off mechanism. Not enough to completely separate the contacts, but enough to cause a slight gap, such that the electricity erratically arcs across it. It may not be enough to see/hear/smell the arcing, but it's enough to draw enough extra current (to arc) to trigger the circuit breaker.
Perhaps take the switch apart and clean the contacts, or get a new switch?
Shootinok
Oklahoma USA
This turned out to be my problem - Thanks!!
I went through the usual steps first, replaced both capacitors, then the unloader valve. It turned out to be just what tak1313 described.
Best of luck OP, this thread was helpful!
