Air compressor pump binds up
Jeno123
Dewalt 80 gallon air compressor 5 horse motor. Air compressor starts old fine then starts getting slow and then binds up if I put my finger over the air intake it picks right back up again immediately until I let my finger off. I've already replaced the switch assembly which did nothing and then I replaced the valve that screws into the tank with a big copper hose that goes to the head of the air pump and a smaller hose that goes to the switch that didn't help either. I know it's out of warranty now but it's basically new
strutaeng
Dallas, TX
1. Remove the belt and see if the motor runs fine.
2. Run the compressor for a bit until it stops. Remove the big copper tube going into the check valve. Does air leak out of the tube (it should not). Can you run the unit with the copper tube disconnected to see what happens?
J
Jeno123
The motor doesn't slow down.It stays at the same speed. It turns freely by hand with a belt on.I have not tried it with it off
J
Jeno123
You're more than likely right on the two belts I agree. I will try that when I get home and see if that helps and I'll post my results. Thank you for all your help
