You can swap pumps all day long as long as they meet up with the rest of the compressor. Typical differences include motor speed and HP, motor sheave, tubing, and bolt pattern of the pump. You can redrill the tank plate for a different bolt pattern, and go with flexilble hose and different adapters or rebend copper tube. If the pump running RPM is different you'll need to change out the motor sheave (pulley). Depending on what compressor you have, it may be cheaper to replace the entire thing and sell the rest on Craigslist. Tanks rot out from the inside out. It would be a shame to pour money into a compressor where the tank is marginal at best.
