strutaeng
Hello guys, I haven't posted in a long time.
I'm trying to determine the CFM on this compressor that I've built. The tank is a 30 gal. CH that was dying. I put a Curtis single state pump that that is rated at 37 CFM @ 125 psi. They recommend a 7.5 to 10 hp motor at around 800-900 RPM. I'm running it with a 5 hp Baldor motor (1 3/8" shaft) at around 550 RPM. I have timed the pump time from 0-125 psi to be 1:38 min and 95-125 psi about 18 sec.
Is there an equation that I can use? Or do I need a sophisticated instrument (that I can't afford)?
Does anybody have a 30gal gas compressor and has timed the pump time? All I need is a rough estimate.
