Air Compressor Question
87bob
Franklin IN
I have an older 80 Gallon 5HP single stage compressor and while it's not an end of the world problem it a frustration one. It leaks down about 20 pounds per day. I have checked every fitting including the drain on the bottom, the exit on the side, both lines coming out of the (head both ends). is it possible that air is escaping internally in the compressor? I don't know where to look for this leak. I used Snoop brand leak detector and did not find it. Any help truely appreciated.
larry_g
oregon
yup, take off the line to the tank ( leave the check valve) and soap that up and see. also the pressure switch could be leaking around the bottom where the diaphragm is
Instead of soap it can also be checked by snapping a simple balloon over the end of the line. If the check is leaking then the balloon will inflate....
87bob
Franklin IN
Thank guys great suggestions! I let you all know if I find it and what it was that was leaking.
