air compressor question
slimshady_2469
i have a craftsman 26 gal. upright air compressor. basic oil-less type.
my question is, would it be a bad idea to mount it somewhere up high on the wall but put it sideways? the compressor motor would be laying on the right or left side depending on how i laid it. hope this makes sense. thanks for the info!
BOONEY7750
I would think the oil would leak pass the rings on the piston? I think that is why you are supposed to let refrigerators and window A/C units sit before you turn them on for the first time, so any oil in the top can run down into the bottom. But I am not an expert.
Garage5.9
Maui,Hawaii
pretty sure oil less means no oil. My compressor (only bigger) you can see part of the crank so im sures theres no oil
Sr. WiNdTeCh
Ill never understand why you would want an oilless compressor. Maybe im missing something.
slimshady_2469
i already have it, its here. its been here for 3-4 yrs now, i just want it up out of my way!
kyleholmes
SWO
I would double check that the bottom end is indeed oil-free, terrible things like 'hydraulicing' can happen when oil seeps past a ring.
another thing to consider is that you would have to move your condensate drain bung.
slimshady_2469
thank you! as far as drainage, i thought about that and just figured i would pull it down and empty it every few uses, i dont use it alot, for some reason i always do things the hard way, hahaha
