Hi Guys,
The second question is: How far away from the compressor should I install the water trap? I don't have one installed now and I need one.
Thanks Tim
The answer might depend on several unknown factors.
I have a filter {which will remove 98% of the water coming out of the compressor in droplet {liquid} form, just a few feet from my compressor. I also have a quick disconnect to supply compressed air at the rear of my garage just downstream from that filter.
After the filter, I have also piped compressed air to the front of the garage about 24 feet away; where I have another quick disconnect to supply compressed air to the front of the garage and driveway.
The filter by the tank outlet removes most of the water before it can be blown into my lines from the compressor tank. Filters however do not remove water vapor from the compressed air. As mentioned, if you have a long enough run of metal pipe - and if the ambient temperatures outside the pipe are cool enough - more water will be removed as the air cools and condenses more moisture on the inside of the metal pipe. In my case I have a water trap & drain in the line at the front end of the garage. Mostly I use that for filling tires - and super dry air is not really required. If I were using that outlet at the front of the garage to run air tools - I'd most likely put another filter at that location as well.
So where you put your filters and/or how many you need - will depend on what your over-all set up looks like and what you use the compressed air for.
If you are spray painting or using a blast cabinet - you might need to get a "dryer" - that will remove most of the water vapor suspended in the compressed air. There are two types of desiccant based dryers - some have a disposable desiccant throwaway filter - and others have rechargeable desiccant {you heat it in an oven to remove moisture - then put it back in the dryer}
hope that helps,
Carl B.
