Air compressor recommendation for weekend work
hc803
There's a hundred threads on here about air compressors, so I figured I'd add another.
Wanting to buy an air compressor to power an impact wrench, DA sander/buffer, ratchet, etc. Nothing over the top, I'm no professional, but something with enough umph to break loose lugs and bolts. I'm figuring 150psi is probably what I'm wanting? Also not trying to break the bank on this but willing to pay for better quality (i.e., I'm not standing in line at Harbor Freight).
Thanks in advance from a long time lurker.
dnschmidt
Phoenix, AZ
The world doesn't care that you're only using it on weekends it only cares about how much air you're going to use. If you're trying to strip a car with a DA on Saturday you need the same 7.5HP two stage 80 gallon compressor you'd need on Friday. Same with a die grinder or a pro level spray gun, an impact somewhat less. Absolute minimum is sixty gallon single stage like they sell at the HD but this is for intermittent usage only. Anything less is just limping by.
kythri
Lebanon, OR
CFM/SCFM is the spec you need to go by, not PSI.
That said, the CFM rating is of the motor/pump ability.
Sanders/buffers/cutoff tools are major air hogs, while impact guns and ratchets are less so.
Tallpilot
Orlando
The big difference between pro and home use is time isn't money so he can probably afford to wait for the tank to refill. I chose a 29 gal 150psi and it is fine for impacts, hammers and brief die grinding. It was $300. IIRC Dennis spray paints which may change the requirements. I don't know anything about compressed air painting.
CFM is critical but PSI also matters. Because of loss in the lines and fittings a 100psi compressor won't supply 90 to the tool. Of course most guys also run their tools 'hot' so more is better.
A 60gal 2 stage would have been $750 and much better. I could afford it but couldn't justify the cost due to my usage level. It would also require a 220/240 outlet which I don't have.
"Don't buy new junk from China, buy a quality used compressor. A properly maintained compressor will last forever." True statement. If it was lovingly maintained, why is the guy selling it? Does the guy buying his first compressor know enough to tell if it's good or junk? I can't.
H
hc803
Maybe this is a question without a definite answer, but what is my minimum CFM/SCFM I'm wanting to look for in order to drive an impact? My title was more for the indication that I'm only doing a few small things here-and-there (tire rotations, shocks/struts, etc), not a full overhaul in a day.
kythri
Lebanon, OR
The thing about an impact is, the CFM ratings they give are for constant use - i.e. holding down the trigger for long (relatively) long periods of time.
That's not typically how most impacts are operated - they're operated in short bursts for all but the most stubborn of fasteners.
As such, while a particular gun may call for a 5 CFM supply, a compressor with a 3 CFM rating will typically perform just fine (my own personal experience with my very first 5-gallon cheapo compressor).
Continuous-flow style tools (such as a sander or a cut-off tool) are FAR more strict about their supply needs. On one of these style tools, and a small tank, you're going to frequently be pausing, waiting for tank refill, then resuming work.
In most cases, you're going to want to consider the CFM rating @ 90 PSI. As an example, this compressor from HD:
http://www.homedepot.com/p/Husky-60-Gal-Stationary-Electric-Air-Compressor-C602H/205389936
Has a rating of 11.5 CFM @ 90psi.
This would likely fulfill most "DIY" needs, but, as always, bigger (i.e. tank, motor HP and pump) is better.
I have two compressors:
Craftsman (Devilbiss) 33-gallon oil-free, rated at 1.7HP and ~5 CFM @ 90psi. This works for most of what I do (impact gun, ratchet, limited cut-off/sanding, etc.)
Campbell-Hausfeld 80-gallon oiled, 7.5HP motor, 2-stage pump, rated at 27.2 CFM @ 90psi. I bought this to plumb my whole shop, which I still haven't gotten around to. I've used it a couple times for some extended sanding work, and the thing is unstoppable. I bought it used for $650, delivered, which I believe was a HELL of a deal, considering the current model sells new for ~$2000.
Used deals are out there, but it just depends on how much you want to spend, and how long you're willing to wait for the "perfect for you" compressor.
I can't say anything truly negative about the 30/33 gallon Craftsman units, and the comparable size units that HF sells get good reviews on this forum (with the vast majority of negative reviews being from the anti-HF crowd with no direct experience with the item in question).
The best research you can do is look at specs of a compressor you're considering for it's CFM/SCFM rating @ 90psi, and then compare that to the supply requirements of a specific air tool that you're considering.
Most 30+ gallon compressors are going to be rated for 150-165psi or more, so supplying a constant 90psi or more is a non-issue.
