I’m moving my compressor to the basement to save space, it’s heated. It will be one floor down so about 8-10 feet. I have access thru the side wall of the garage. I need advice on how to bring the air to the garage. It’s a 15 year old craftsman 20 gallon 110 volt 5hp compressor with a dial regulator and drain hole in the bottom.
I will be using it for air tools but no painting, possibly sand blasting later...it will be connected at all times to my car lift.
Do I just use a long hose with a splitter? Can i relocate the dials that are there now?
Do I need to go in the basement to adjust the PSI output?
Should I look for an outlet( don’t know the name) or similar and wall mount it?
It will have a drain right next to it so that’s a plus. Can I put in a remote drain?
Thanks
Thanks
