dusterbd13
so I bought a new to me compressor. the seller told me about an issue that I wrote off as not that big of a deal.
well, apparently it is.
on the pully side of the case is this fitting:
it appears that it should be a press fit, but it is loose. it has a red cap over it that does not look original. when the compressor runs, it leaks oil out around the fitting. not the cap.
my thinking is that I need to pull the red cap (looks like a parts store vacuum cap) and epoxy the fitting in. what do I need to do to fix this before changing the oil and putting it into the storage area plumbed to shop air?
all the pictures I took should give any info you need, but if you need more, let me know. this is my first oiled compressor. ive always had oilless.
