Compressor is doing great, apnost done cleaning up shop so I can start using some tools.
I looked more into this sheave sizing.
Motor is 8" while pump is 14". According to a calculator the motor at 1725 would be driving the pump at 986 rpm.
The pump is rated at 1725, obviously I could put a 10, 12 or even 14" sheave on the motor.
But would I gain anything besides decreased runtime? Is running a pump for 90 seconds at 1700 rpm gping to put less wear than running for 3 min at 1,000 rpm, or is it a push?
You will get more flow. Yes, you will fill the tank faster if you're just using a little air and the tank pressure drops below the cut in pressure, but if you're using a lot of air constantly, the amount of flow will dictate how long you can work before dropping below the regulated pressure.
Spinning the pump faster is how a lot of compressors meet the advertised CFM, but often it is at the cost of additional heat and noise. The best compressors are able to make high flow numbers at low RPM, minimizing heat and noise.
If you can measure the current you're drawing as the compressor reaches nearly full tank, you can guess at how hard the motor is working with the current pulley setup. If, for example, the motor never draws more than 15 amps, (depending on the motor rating) you've probably got some headroom to run a little larger drive pulley. But if you're already near the max nameplate current, you might be taxing the motor too much to increase the load.
It will also get noisier if you run it faster.
