I will start by saying I do not own any pneumatic tools, and I do not intend to buy any pneumatic tools. To be honest I know very little about and have almost no experience with in-garage compressed air systems.
That being said, what I am looking for is some kind of air compressor/tank solution for my garage to primarily air up my car tires. A bonus would be bike tires (although I have a hand pump that works just fine for that) and to have a source of compressed air to blow out/clean things with.
Based on this, what is a good solution for me? Obviously I don't need a giant compressor and 80 gallon tank, honestly I am not even sure I need one of those little combo units with a compressor and pancake or hotdog tanks either.
What I want is something that is small and easy to carry around, so I can carry it to each of my four tires and hopefully not have to deal with long extension cords or long air hoses. I know a lot of people might recommend a 12v-powered compressor but I would rather have something that I can power with 120v AC as I don't want to have to pop the hood and wire into/drain my car battery every time I want to air up. And I intend to leave the compressor in the garage not stow it in my car.
What I have been thinking is to get some kind of standalone compressor, and then maybe one of those hand-carry 5-7 gallon air tanks? So I would just fill up the air tank, and then be able to carry that around to each of my tires and fill up as needed. The logic being that just carrying the air tank around itself is lighter than hauling the compressor along with it. Is this the right way to go? What kind of compressors are available that do not have integrated tanks?
Another thing I'm thinking with this type of set up is that I can take the air tank with me outside and have compressed air available to me outside in the yard or in the shed, etc. too if I need it. And since I'm only carrying the tank and not a tank + compressor it will be easier to manage. Also a 5-10 gallon air tank seems to be about the same size/weight as a smaller 1-3 gallon compressor+tank combo, so under this strategy I am devoting more weight to carrying compressed air around and not wasting effort on carrying a compressor around.
My dad has some kind of air compressor in his garage it does not have an attached storage tank. It runs off of 120v and is a little bit bigger than a shoebox. It puts out up to 100psi air I believe (unknown CFMs) and has a 5-6ft air hose on it. It works good except like I said it is annoying to have to get out and set up an extension cord every time (the built in cord is too short to use without an extension for airing up car tires) and then coil back up both the air hose and extension cord when you're done. I'm thinking if I had some kind of small air tank I could set up the compressor somewhere and then just fill the air tank when I need air and take with a short hose (2-3 feet) to fill the car tires.
What do you guys think, any advice? Like I said I don't have a lot of knowledge about compressed air so maybe I am overlooking some other kind of solution. The only thing I have ever used compressed air for in a garage is to air up tires (which I find VERY useful because then I don't have to go to a gas station to do it!).
Ruahrc
Ruahrc
