Air compressor starts with low pressure
diggerwolf
Van Alstyne, TX
My old, inherited air compressor finally gave up the ghost. Using my backup now. However, it exhibits a weird problem when I use it.
Although it seems to fill, no leaks, and holds pressure, when I first start using it, whether a blow gun or air chuck, the pressure is incredible low at first, then builds up.
What would cause this, and how do I fix it?
Thanks!
finn
The UP, God's country
Check valve leaks, letting the tank drain down until the power is turned on and the pump starts.
That or the tank is rusted and has pinhole leaks on the bottom.
If the gauges in the first pic are correct, sounds like your regulator is fouled up, and self rights later as it gets used. Or **** in the hose that gets blown out.
u3b3rg33k
I replaced my cheapo regulator with a REAL regulator, and WOW what a difference it makes having one intended actually flow air and not just exist at a low price.
Citation
Indy
Given the 125psi max pressure you could probably just skip the regulator. Also, you might be able to clean/lube the old one. However, replacement is generally easy.
BTW, it's not clear from the description, are you saying the tank pressure drops or just the pressure out of the regulator is low until you use it a bit? Anyway, if the regulator fixes the problem you will know what the problem was :D
Hohn
Diesel Central, Indiana
100%. Replaced my cheapo that came with it with a standalone Milton with 1/2 NPT ports. Huge difference.
